Kim -
The odd thing is that I actually did use the sock in front of a return method... I started by putting it in the skimmer, but it didn't seem to really be doing much, so I put the sock over the side of the pool, in front of the jet and left it over night. It was mostly gone the next morning... That evening I was around a 30... My pH has dropped to a 7.0...
That said, here is some good news - I think... After adding bleach last night and waiting about an hour, my FC was 14ppm. This morning, before the sun came up this morning I checked it and my FC is at 13ppm. So, I only lost 1ppm overnight... So I think the water is reasonably clean (at least there is nothing alive in it).
That said, I have a few more questions:
1. As the pool passed OCLT, but is still cloudy, do I keep the FC at shock level of 10ppm, or is now the time to adjust it down to the 3-4ppm associated with the SWG?
2. Regarding the other levels, what order do I follow in adjusting, as I know changing one will likely effect another. Is this right?
a. Salt
b. CYA
c. pH
d. TA
e. CH
As I adjust one of these levels, is it appropriate to anticipate that I should wait 30-45 minutes between adding the chemicals and testing to see how it looks?
Finally, on the cloudiness I see in the deep end - is that just a matter of continuing to brush/filter the pool and wait for the sand to filter out whatever is causing the cloudiness? Is FLOC necessary, or will the chlorine itself clear this??
So far, this has been a reasonably easy experience. I am actually enjoying seeing the changes...
