Hi TBF,
Looking for some advice for a new home-owner on my first pool opening (performed by pool manufacturer staff).
At pool opening, a leak on the pump a leak was found, and system was off for 5 days until the repair took place. 5 bags of shock were added at pool opening.
When able to start the pump & filter again, the pool store tested a very high value of phosphate & combined chlorine (possibly from mulch? There aren't many trees around the pool)
Pool store recommended Phosfree. Added 1.5L as per instructions which brought the phosphate down after ~18hrs, from 4900 to 4400.
Plan is to backwash after 48hrs and then add the remaining 1.5L of Phosfree.
Store also recommended Scorch treatment AFTER the phosphate levels are back to normal.
Can the oxidizer be added before the full phosphate reducer cycle? Is a backwash mandatory if pressure is still within normal range?
Store also recommended to remove chlorine tablets from chlorinator during this process. Would you agree?
Free Chlorine: 0.33 ppm
Total Chlorine: 1.69 ppm
Combined Chlorine: 1.36 ppm
pH: 7.7
Hardness: 263 ppm
Alkalinity: 88 ppm
CYA: 27 ppm
Phosphate: 4911 ppb -> 4400 ppb after 18hrs
pH: 7.7
Hardness: 263 ppm
Alkalinity: 88 ppm
CYA: 27 ppm
