For the past few months I've been having stubbornly high PH. It stays about 8.0 - 8.2. I can push it down with muriatic acid, but over the next few days it returns to that low 8 range.
Is this "where my pool stays" or can I make some other adjustments to help the PH stay lower? The pool is clear, otherwise fine to be in - but I know the PH is out of whack.
FC 4.5
PH 8.0
TA 100
CH 500 (note that this where my kit turns "purple" not quite blue. I have to put in like twice as many drops to get it to a true blue. I've tried the modified instructions using 10 & 3 drops - but I still get about the same result.... so maybe my CH is higher than this.
CYA 50
Hope I provided all the info... thanks!
FC 4.5
PH 8.0
TA 100
CYA 50
