My pool is two years old. As of May 2018, my CYA got very high, and I could not hold a chlorine reading. I had been using pucks & chlorine granulates. It was at this time that I started reading TFPÂ’s site and switched to Liquid Chlorine and got my CYA down. I now can hold a Chlorine reading. Here is my issue. My Ph is high. I keep it at 7.8 or below, but I use a lot of Muratic Acid to do so. It seems impossible to keep it around 7.4. If I get it down to 7.4-7.5, It will be at 7.8 within 24 hours or less. If I donÂ’t add some MA when Ph is 7.8, it will rise to 8 or above in a day.
Todays readings before adding anything. TC 1, Ph 7.8, TA 100, Calcium Hardness 275, CYA 40-45. Pool details are in my signature.
Short story is I have no problem holding a chlorine reading since getting the CYA down. Usually, when I add Liquid Chlorine, I add no more than 1/2 gallon at a time. I am using 8.25% LC. Since last Sunday, Sept. 2, I have used 1 gallon, 1 quart & 1 cup of LC (21 cups). I have to use a lot of muratic acid. Since Sunday, Sept. 2, I have used 1.125 gallons (18 cups) of Muratic Acid. My TA doesnÂ’t drop dramatically quickly, but I do have to add about 5 lbs of baking soda/sodium bicarbonate about every two weeks to keep the TA above 100.
From reading this forum, it doesnÂ’t seem to be normal to have to use so much MA. Ideas? Looking for help to stabilize Ph.
This is my first post in TFP forum. I tried to put all the necessary info in my signature. Let me know what I missed.
Thanks.
Thanks.
