- Feb 8, 2022
- 100
- Plaster
- CircuPool RJ-16 Plus
I messed up. My FC level has been at 23 fc with 2 CC with a cta level of 50. 3 days now. Would it be safe to swim in today?
2 ppm CC seems unlikely unless you used MPS of sulfamic acid.My FC level has been at 23 fc with 2 CC with a cta level of 50. 3 days now. Would it be safe to swim in today?
Why is the FC elevated?
Were you doing a SLAM?
Did you have CC before the FC was raised?
If no, then the CC seems very unlikely.
I am getting ready to add a SWG. I was trying to get the water balanced. I also have 5000 ppm of salt in my pool. Have to drain every year due to high salt content in city waterDo you have a SWG or a liquid chlorine feeder?
Are you adding chlorine manually?
Did you add too much unintentionally?
Chlorine has not gone down for 2 days now.2 ppm of CC indicates that the SLAM is not complete.
Did you do an OCLT?
Most likely the CC will be irritating.
It is well water, I'm in buckeye. Sorry it was the salinity test from my tf100 pro salt kit. 10ml of water, one drop of 0630 and 7 drops of 0718 to turn brick color. That happened instant from a yellowish color to brick.How did you test Sodium? Most tests are for Chloride. That level in tap water is pretty high. Are you on a well? Where in Arizona?
Your salinity may increase a bit over the year. Mine does. But then I harvest some rain water in the winter to reduce it.
City does treat the water then it gets sent to my house.It is well water, I'm in buckeye. Sorry it was the salinity test from my tf100 pro salt kit. 10ml of water, one drop of 0630 and 7 drops of 0718 to turn brick color. That happened instant from a yellowish color to brick.
7x200=1400ppm saltIt is well water, I'm in buckeye. Sorry it was the salinity test from my tf100 pro salt kit. 10ml of water, one drop of 0630 and 7 drops of 0718 to turn brick color. That happened instant from a yellowish color to brick.
Thank you. I will need to drain some. My current salt level is at 5000 ppm.Still seems high. Just monitor your salinity. The IC will work fine up to 4500 ppm or so.
