My CYA level is too high and I was told by Leslie's that if I leave the pool circulation OFF for 4+ hours that the CYA that is in the water will float more to the top and therefore add water to the bottom (put a hose in the bottom of the pool) and by adding water to the bottom more CYA will leave since it has floated to the top and you are overflowing your pool.
All the forums say correctly that CYA should be distributed evenly within the water when the pump is on, but is there a case where if the circulation pump is off that the CYA will float to the top and be more concentrated there? My pump stays off for 14+ hours every night.
