I am a newbie trying to wrangle the pool of a house I just bought. The pool *looks* great, BTW, for some reason. Perhaps it's too toxic for algae to grow.
I had been testing free chlorine and ph with the daily kit while doing the move, and CYA only with a test strip. So, what I thought I knew was that pH was low and CYA nearly non-existent. I kept adding soda ash with no apparent improvement, and must have overdone it in the last round, because now the pH is high, the other tests are now suddenly working, and CYA is "drain the pool" high!
From the pool store's water analysis (vinyl pool, ~17,000 gallons, ~82 deg F):
Free chlorine: 5.8 ppm
Total chlorine: 6.8 ppm
Combined chlorine: 0.96 ppm
ph: 7.8
Total akalinity: 157 ppm
Calcium hardness 7 ppm (yes, 007)
Cyanuric acid: 129 ppm
I confirmed enough of this, including CYA, with my own test kit to be comfortable with the truth of it.
So, ... bummer. It appears that there is no point in doing anything until I drain and refill a lot of water, correct? I have a vinyl liner, and I don't want it to get sloppy, so can I drain the vertical part of the pool and stop short of exposing any of the bottom, then fill and test again?
Doesn't seem like there's any point in addressing any of the rest of it until the CYA is down, because I will be testing 50% (or more) tap water next time, right?
Also, just out of curiosity, do I *need* calcium hardness in a vinyl pool? I need to add 30-some pounds to get it up to a normal range according to the pool store.
Thanks for any advice.
/// Rob
ph: 7.8
/// Rob
