I was able to SLAM my troubled pool successfully earlier this year, thanks! Now I am curious about long term strategy for keeping my alkalinity in check. We have extremely high alkalinity city water (I tested at ph 7.4, alkalinity 300 ppm). Currently, I'm consistantly adding acid which has it down to about 150 ppm. Is there any hope for a long term solution that doesn't call for consistant acid purchase in my future do to always adding high alkality water from evaporation? I've read some of the following in these forums and curious to get takes:
1) Don't worry about alkalinity unless your ph gets too high. This seems like a possibility, but at such high levels of alkalinity I think I would be consistantly too high with my saturation index. I also have hard water (~350 ppm), and thus high saturation index. Maybe if I found a way to add water from my house after it's been softened, I could get away with this?
2) Other ideas?
3) Continue to just add acid for the rest of my pool's life? In this case, basically, it sounds like I just need to continue to keep it at a level where I can keep my saturation index at 0.3 or lower. Or do other people with high alkalinity water let it go higher?
Basically, I'm thinking there is no silver bullet for having 300 ppm Alkalinity fill water, but looking for guidance from the group on the least bad option and maybe advice on what things are highest priority, and what things I can maybe give a little on (for example higher saturation index okay as long as PH stays in check???).
Any advice much appreciated.
Kyle
2) Other ideas?
Kyle
