- May 3, 2014
- 63,121
- Fiberglass
- Pentair Intellichlor IC-40
Your fill water has a CH of 250 ppm. From Lake Mead. You evaporate a bit less than I do each year, so less than 2 pool volumes. If you drained and replaced the water in May (which would reduce your overall evaporation amount as late March and April are strong evaporation times) your CH should be no higher than 750. Likely closer to 600 ppm.
