Kelly,
I'm gonna be at work most this weekend, so I'll post my suggestion to you here so that others can help you out.
You are at a major advantage having a smaller above ground pool on this case. Often, the only time a drain is suggested is from high CYA, however in your case I feel its a good idea. For $30 you can be swimming in a day.
1. Drain your pool leaving a foot of water to prevent wrinkles.
2. Fill with fresh water
3. Add the CYA to raise to a 20. To do this you will add 1 pound of the stabilizer you bought. Do not use pucks or powdered shock to raise the level. At this point it will be easy for you to overshoot your goal using these products. Stick with 1lb of stabilizer.
4. Add 65oz (8cups) of 8% bleach with the pump running.
5. Test and adjust PH as needed.
6. If water is clear.......go swimming.
Daily until your K-2006 arrives,
Test PH and FC and adjust as needed. Keep the FC a dark yellow at all times, as this will hold off more algae. As soon as you get your new kit, post full test results.
The majority of the time I wouldn't suggest a drain, as there are many unknowns here. At this point however I would for the sake of time. For $30 you'll skip a lot of work.
Keep reading pool school and asking questions. Just remember,
It's only water!
