The test you are showing with the yellow block is an OTO test. This is type of indicator chemical you are using.
a quick goggle found this about this test and other common ones we discuss (with my additions)
OTO (or OT): Abbreviation for the chemical reagent orthotolidine originally used for determining chlorine levels. OTO can only measure the total chlorine level and turns the pool water yellow upon addition. (teh test block is marked to 5PPM, but the colors shown far higher but are less accurate the further the get above 10PPM)
DPD: Abbreviation for the chemical reagent N, N-diethyl-p-phenylenediamine that is used in drop tests to determine both total and free chlorine levels. The pool water sample turns pink upon addition of DPD. (This is the test that is limited to 5PPM)
DPD-FAS: This term refers to a variation of a DPD test that uses titration to determine the measure of free and combined chlorine down to 0.2ppm. FAS, ferrous ammonium sulfate, is the reagent added by titration until the solution changes from pink to colorless signaling the endpoint of the reaction. ()this is the test in the TF kits, it is accurate to 50PPM and can differentiate between FC and CC, not just TC like the other two tests)
Phenol Red: The most common reagent used to determine pH, phenol red works on a range from 6.8-8.2.
