So, yes, don't have to do it now, but I would drain 3/4" from the pool at some point. That will allow you to skim at lower RPM and save some $. Likely not much $, but it will make skimmer more efficient. Do you have a sump pump that you can use? Not really recommended to drain with the pump. I got a cheap one and use it all the time to drain and aerate.
You are certainly getting there. Still a bit of haze / lack of clarity, but you are getting closer. If you have the time to check every two hours, that would be great and speed results.
One last thought. Did you happen to notice your the pressure on your filter after you cleaned? If so, if your pressure rises by 25% (Filter pressure clean at 1800 = 20, current pressure 25) you will want to clean the filter again. My guess is, given the state of your pool, you are fine. When SLAM is done, I would clean the filters again and note your baseline pressure and RPM. Log it in pool math as a note or put it on a sticky somewhere.
You will get this!
