Pool has been drained and refilled. Got a chance to seal under the boulders that intrude into the pool edge, as well as, seal between the tiles and pool deck. I had a pool person come in to acid wash some heavy duty calcium deposits, again where the boulders fo the wall fall meet the pebble tec surface.
I allowed the pool person to set up the water. He left me a gallon of liquid chlorine and a mix of stabilizer/conditioner and Tri clor. At his instruction, when the pool was 1/2 full, I added 1/2 of the powdered mix that was dissolved in water. When the pool was completely full, he instructed me to add the rest of the dissolved powder mix and the chlorine.
The pool is remarkably clear but I seem to be adding acid about every three days and I cannot seem to reduce the pH. The readings that will follow show my Cl high. I had a .06 reading and based on the pool calculator, I added the prescribed amount of bleach but as you can see, way too high now. Any ideas on how to get my pH to behave?
Also, I see a constant reference to using bleach vs liquid pool chlorine, is there a particular reason?
Many thanks for the help.
Here are the reading from my testing:
Cl drop: 9 ppm
CC drop: .05 ppm
Calcium hardness: 325
TA: 100
CYA: 38
