- Jul 16, 2021
- 31
- Plaster
- Jandy Aquapure 1400
Hello,
I have a not even 2 year old 9550 sport that recently started giving me Error 10 codes after leaving it in the pool for over 2 weeks. I try to take it out when it's not in use to prevent issues, but alas, here we are. I read online that it's an issue between the control unit and the cleaner. Checked the connection at the control unit, all looks good, so decided to take apart the cleaner. Found water in the connection point. The screws were tight, so not sure how water got in there. I opened up the motor compartment and it's bone dry. No signs of moisture. How would you suggest cleaning these connection points? Thanks in advance.
Or is there a way to completely replace the pins in the first pic below? looks like the corrosion goes all the way to the actual cable.
