Pool opened 10 days ago, still blue and milky, looking for help to clear it up.
1. Last year, before closing, water was cloudy and I didn't totally clear it up before closing.
2. This year pool was opened 10 days ago. All green and algae.
3. Add 12 gallons liquid pool shock first, after overnight, FC was 0, so I add 2 gallon algaeacid, not much help.
4. Then I add 10 lb granule chlorine once, next day or two, add another 10 lb. Pool green is gone, became blue and cloudy.
5. Tried pool clarifier, didn't improve.
6. Add 3. Qts phosphate remover, still not help.
7. 3 days ago, added 24 oz pool flocculant, wait for 48 hrs, getting better, but didn't totally clear, can see the bottom at shallow end, not deep end.
8. Yesterday, vacuum the bottom, pool now blue and milky, FC reading is ok to high with test strips.
With test strips reading, FC is good, PH is a little low, TA is a little low, stabilizer is low. I am using SWG, salt level is 3600.
What should I do to make the pool clear?
