Just started up the pool and have been running it for about a week now. Most of the pool is in balance except for the salt; which I'm waiting for the temps to climb a little. Right now she fluctuates between 55-65 as the outdoor temps are still low.
She's run perfectly fine for several seasons but I did a pretty big drain this past winter. The generator shows 144, which I know is low salt. Once I get a nice steady 60+ of water temp I'll add salt into it. I'm not expecting chlorine generation as of now because of this.
What is new is that she shows "No Flow" with a blinking green light for Sensor Flow on the tri-sensor (Program A). Also new is the temperature is displaying weird. Upon pushing temp/boost, it will show fluctuating numbers from 34-40 at a rapid blink. Usually it'll just give me a consistent single number. I've attached a video to help.
So far, I've done the following
1) A breaker reset.
2) Pump shut off, restart.
3) Pulled the panel apart to see if there was a calibration button, but there wasn't one.
4) Removed the sensor and the cell from the fusion and they both look clean without any buildup. Just in case, I also did an acid wash of the cell.
5) Checked flow with pump at 65% (50gpm)
6) Increased pump speed to 90% (80gpm+ at meter)
Again, I'm not expecting chlorine generation because of the temp and salt levels. But I'm not sure if it should still see a flow condition with low salt as well as providing a consistent temperature. My pool heater is plumbed right before it and the water flow sensor does trip and turn it on (40gpm required) and the water temp on the heater reads 64 when I took the video.
I'm guessing I need a new sensor but I wanted to get the forums thoughts on it as well before I threw money at it. Thank you in advance.
1) A breaker reset.
