After pool opening this season my Aqua Logic control board started operation with the problem known before, but not in the way discussed here or elsewhere. I wonder if anyone observed such a problem and found the way to fix it in other ways than just replacing the board. After starting the pump, it powers the T-15 cell normally , but after a while it cuts off power to the cell and throws out Cell Power Error message. All chemistry is verified normal. The length of normal operation depends on chlorine output. At 40% output, the length of operation before Cell Power Error is approx. 53 min, but at 5% it is only 9 min. Flipping the breaker (total powering off) clears the error, the cell powers normally in reverse (-26.32 V, -5.97A, instant salt 3.1 g/l), but after a while everything repeats again. When during the normal cell operation the pump is turned off manually, the board powers off the cell without No Flow Error. If the pump is turned on right away, the cell is powered normally in reverse. However, after few minutes while the pump is still off, No Flow Error shows up. Now the board fails to restore power to the cell after the pump is turned back on and No Flow Error changes to Cell Power Error. Following recommendations, I first re-soldered the K-1 relay - no help, then replaced the relay with a new one - no help, the same behavior. It appears that the board powers off the cell to reverse polarity, but then does not power it back and throws out the error. Perhaps something faulty in the electric chain to/from the the K-1 relay, a condenser or a resistor, may be a simple reason. Any idea what could cause the board behave in such way?
