My wife and I are in the planning stages of a new pool build. I have a strong construction background so we're planning this as a DIY project using a liner pool system. We live in Southern Maine and ground breaking will be this spring. Here are a few initial details:
The pool will be located in our backyard just beyond our gazebo. I've attached a few photos of our backyard and gazebo area. Obviously, modifications to the landscaping will be needed.
Let us know what you think and what you'd suggest. We're all ears!
- We're leaning toward a lagoon shaped pool along the lines of what's shown on this plan. https://poolwarehouse.com/wp-content/uploads/2018/01/16-X-34-X-25-X-LAGOON.pdf
- Flat bottom to provide a consistent 4' water depth. We're on the shorter side and prefer to float\wade\lounge rather than tread water.
- We'd eliminate the exterior pool steps in favor of a liner-over step system with a tanning ledge.
- We're debating adding a swim out in one of the coves to provide a second seating/lounging area.
- The pool surround / patio will likely consist of CIP concrete coping with a paver patio.
- We're thinking about strategically placing some sleeves/inserts in the patio / coping for pool umbrellas.
- We're totally on the fence regarding the sanitation system. Chlorine, salt water, UV, Ozone, etc...
- Selecting a pool pump and filter system.
- Advice on pool lighting (approach and lighting type). I'll add that we nearly fell over when we saw how much the LED pool lights cost.
- Suggestions for pool cover options. Not sure how best to address a pool cover for free form pool.
- We're contemplating a solar heater to help keep the pool temperature up.
