I have an older style pool (perhaps 70’s or 80’s). I’m trying to upgrade the light (assuming 500w) to LED. The problem is there is no screw at the top of the light. There is a metal indentation which I tried to turn with an Allen wrench (which kinda fit) and with a socket wrench with Allen bit. The screw or whatever it is didn’t budge. I’m not even sure it is an Allen screw. I tried to pry back the metal ring a little to look behind it, to see if I could see a screw or bracket or anything going into the light opening. I do see some sort of calcified attachment. Not sure if it’s a screw, a bracket, something the screw goes into or what. Please help before I start breaking things! I’ll try to attach an image. Not sure what you can see in it, since the angle is weird and the light is too far below the waterline to get a good shot.
