I just tested my water with the following results (TF-100 kit)
FC: 5.0
pH: 7.5
TA: 200
CH: 750
CYA: 135
I had light mustard algae on the walls from the tile line down about 12 inches. I brushed it all off.
The water is cloudy, because I have a lot of fine grain particles in the water. I may have over fed my DE filter with DE after my last backwash last week, or my filter membranes have hole in then.
I think I need to drain the pool about 2/3 rd tp my CYA down to 60 and the get my DH down to about 300.
Should I vacuum first, before draining?
I assume I should focus on the water balancing after I refill.
Any and all help is appreciated.
FC: 5.0
pH: 7.5
TA: 200
CH: 750
CYA: 135
