Hello,
My new Wilbar Intrepid 12' x 24' pool arrived a few days ago and I'm in the process of digging. I'm now at the stage where I need to carefully consider where to lay pipe, put in valves, T's, etc. I drafted what I think would be a good setup but would love if someone with experience could chime in and give feedback. The layout is a bit odd since space is tight and I am hoping to use my existing 2x20' solar panel that is on the complete opposite side of the pool as the new 2x12' panels I will be adding. For reference, the distance between the sets of solar panels is about 35 feet and the distance between the "T" separating the solar panels to the pump is about 25 feet. I'm uncertain whether I may need more check valves to prevent one set of solar panels from having a higher flow resistance than the other and potentially being inefficient? Any other advice about where you might put other valves (ball?) for maintenance, flow adjustment, etc would be appreciated. Schematic is attached along with pictures of the digging area and my digging buddies.
Thanks!
Thanks!
