The pressure before the grids should always be higher than or equal to the pressure after the grids.
If the flow is completely blocked downstream of the filter, the pressure before the grids will be the same as the pressure after the grids.
The pressure in the standpipe should never be higher than the pressure in the filter or inside the grids.
Maybe the grids are filling with air and floating up?
