- Oct 1, 2021
- 1,434
- Plaster
- Pentair Intellichlor IC-60
Hi friends, I’m ready to buy myself a robot. I’d like to purchase from Amazon since I can buy the extended warranty and shipping and repairs are covered. I have a 15k gallon in ground plaster pool that is roughly 30 ft x15 feet. There are 3 shelves and there are also 3 steps. My needs are that it must be able to effectively climb the walls and brush/vacuum without getting stuck all the time. I’d like to be able to program it to some extent - must be easy to use. I expect it to last 4-5 years.
In my Amazon search the following seem like options (in no particular order):
1. DOLPHIN Nautilus CC Automatic Robotic Pool Cleaner - Ideal for Above and In-Ground Swimming Pools up to 33 Feet - with Large Capacity Top Load Filter Basket… https://www.amazon.com/dp/B01N78IVWJ/ref=cm_sw_r_cp_api_i_YSEXRK4BCQ2FZ6SFZXEN
2. (Not sure what is different about this one than #1 aside from the 50 ft) Dolphin Nautilus CC Plus Robotic Pool [Vacuum] Cleaner - Ideal for In Ground Swimming Pools up to 50 Feet - Powerful Suction to Pick up Small Debris - Easy to Clean Top Load Filter Cartridges https://www.amazon.com/dp/B00Q8M0NWE/ref=cm_sw_r_cp_api_i_FZ7WGME33CYG9BA11QA4
3. (They also have a Dx4 but again only difference I see is 50 feet) DOLPHIN Proteus DX3 Automatic Robotic Pool Cleaner, The Quick and Easy Way to a Clean Pool, Ideal for In - ground Swimming Pools up to 33 Feet https://www.amazon.com/dp/B083YZG3LV/ref=cm_sw_r_cp_api_i_15BBBXQW33RD29BKSCDF?psc=1
4. Dolphin E10 Robotic Pool [Vacuum] Cleaner - Ideal for Above Ground Swimming Pools up to 30 Feet - Powerful Suction to Pick up Small Debris - Easy to Clean Top Load Filter Basket https://www.amazon.com/dp/B01BUE8XVC/ref=cm_sw_r_cp_api_i_TXCGS8ST9X05GQQ71PWQ
Should I aim for more than 30 feet since my pool is 30 feet or is it fine to trust a 30 foot range? Which of the above might be appropriate for my pool?
Would be grateful for your input!
