Hi Guys
My diffuser in my old 2 speed pool pump died. So I wanted to replace the pump -- and quick so I went down to my local Leslie's and bought a Pentair 11056 VSF pump
I couldn't get a tech here to install it, so I decided to do it myself.
I have a iaqualink RS system and I figured I could just replace the 2 load lines with the new load lines from my Pentair...
I went ahead and removed the common wire that was going to the 2 stage pump relay... and removed the black wire from the 2 stage relay that went to the old 2 stage pump -- since the new pump isn't 2 stage, it only has 2 hots and a ground... vs. the old 2 stage which had 3 hots and a ground.
The other thing I did was change the DIP switch 2 to OFF (setting it to 1 stage vs 2 stage)
However, I didn't remove the 2-stage relay, just left it in.
So -- now after install, when I turn on my iaqualink ... I can access the control panel via the web/phone app ... however, nothing I turn on results in a relay clicking on.
No "life" to the new pump. No waterfall, no nothing.... Relays just don't seem to do anything.
Anyone have any idea what I could do to debug the situation? Or anyone ever have a issue like this before? ... perhaps my iaqualink died? ...which would be weird since I can access the webapp, and when I turn on pumps, or the waterfall, or lights .. the RED status light on the pump or light comes ON, but nothing happens ... like the relays are triggering.
Anyone have any advice?
