Hello!
We're looking for any insights in case there are any solutions we are missing.
We moved into a house with a 20 year old pool last year.
It was mostly ok in the winter to keep balanced, but right now it's almost impossible.
The PH raises by .2 - .3 every day. This means dumping in a gallon of muriatic 3x a week to keep PH in line.
Pool Alkalinity is usually a bit low due to all the muriatic, about 60 right now. Raising it doesn't last long.
The primary salt cell is set to 100% and must run 24/7 and barely keeps up.
The chlorine completely evaporates daily and needs to regenerate over night.
We turned the autofill off to see how much evaporation is happening, it needs about 1 hour of full blast hose water daily to keep full. It did not leak during the winter. The pool temp is currently 89deg just from sun.
The pool does get quite a few leaves which could be contributing to balance. We empty the skimmer daily and use an additional skimmer bot. We run a pool floor cleaning bot daily.
Does this all sound normal for a “larger” pool in a hot climate or is something not balanced? Do you see other solutions to automate this more as we can’t leave the pool alone for more than 2 days. Pool service isn’t feasible at this level of upkeep as most services only come 1x a week and this needs daily or every other day maintenance.
How are others managing with just weekly service? Would love any advice for anything else we can do to simplify the upkeep!
- We resurfaced the pool, upgraded all pool equipment last year.
- We filled it with fresh water that has stayed balanced for the past year.
- It is a 35K gallon free form pool.
- 8ft in the deep end, beach entry on the other side.
- It’s a salt water pool w/2 salt cells; cells are brand new.
- There’s an in floor cleaning system and only 1 skimmer (not sure why, there were 2 in the permit.)
- It has 2 floor cleaning pumps, 2 filters (recently replaced), and additional pumps for waterfalls & spa which don't run often.
- We are based in Las Vegas.
- The pool gets direct sun most of the day.
