Hello,
Put up an AGP, and currently filling it up. Great site BTW, actually using the overlay liner trick on my Intex as the seam is leaking. I took my first set of water tests just to see where I'm at (been pool filling the past 18hrs). I'm going with a SWG and haven't put anything in the water yet. With the FC low and of course CYA and salt at zero at the moment, should I get the salt in there now while the pool finishes filling up and then once the water gets over the jet add bleach and get CYA up to 70 (sock technique)? Then after things settle over the next 24hrs, re-test and focus on lowering the PH?
Taylor 2006 Test Kit / Taylor Salt Test Kit
FC - 1
CC - <1
pH - 8 (think it's higher it was more red/pink than the test window)
TA - 40
CYA - 0 (still filling pool, almost getting above the jet)
Salt - 200
FC - 1
CC - <1
TA - 40
Salt - 200
