I have an Intex prism frame pool that has the light gray color top portion and white support tubes that insert through. Each location of a Tee joint for the legs has an exposed open area that water splashes out. I also believe that my saltwater is more likely to get inside of the poles through this splashing and lead to rusting more quickly. So I want to patch over those gaps for the inside portion of the pool and also cover the top portion of the pipes. I think 24" wide by 12" should cover each of the 20 areas. The pool stays up year round.
Only I cannot find what I want in the light gray intex color. I would prefer peel and stick as this is not load bearing or under water. Vinyl cement is ok if I have to.
here is an example: ebay "used" patch
But it is the color pattern of the bottom of the pool and not the gray that I am looking for.
here is a link to the actual pool I have: intex prism frame
I would even be ok with a roll of the stuff if you know of a source.
