The only way to get the SWG in there is a vertical install. That means you also have to calculate 4 90° bends which causes head on the pump and some kind of reduced flow, but not sure how that gets figured.
I see if the flow decreases would it decaerse the ability of the swg to work properly ?The only way to get the SWG in there is a vertical install. That means you also have to calculate 4 90° bends which causes head on the pump and some kind of reduced flow, but not sure how that gets figured.
Yes that how the pool installer did it. They installed the fiber glass pool and pluming and I did the electrical. Why is that a problem through the heater always ?Your single speed pump will provide sufficient flow to close the flow switch. I would be more concerned with the flow rate through the heater all the time. I suspect that the internal bypass on the heater is open most of the time.
Are you going to get this professionally installed? If not, there are better SWCG's to install for warranty purposes than the Pentair.
Can you fill out your signature please?
Is the heater by pass a must? I don’t know why they didn’t install it. My set up is just one loop out the pool pump filter heater and back to pump no check valvesYour single speed pump will provide sufficient flow to close the flow switch. I would be more concerned with the flow rate through the heater all the time. I suspect that the internal bypass on the heater is open most of the time.
The heater has an internal bypass when the flow is too strong.
What is your current filter pressure with pump running?
Hayward has a warranty for DIY install. Be aware of that.
Yeah I talked to Hayward they said warranty would be the same if I install. Just than in my readings on this forum I came a cross people that had problems from the electrical control of the aquarite system. Pentair you get a new control with every cell. Warranty is only a year of install by professional,The heater has an internal bypass when the flow is too strong.
My pool was built with Pentair equipment. When installed with 3 items, you get a 3 year warranty. Had warranty claims for a light and the flow switch.
Your filter pressure is pretty low. What filter do you have? Please add that to your signature. Also HP of the motor on your pump.
I just purchased the CIrcupool RJ60 plus and will install this weekend. I'm not planning on putting in a check valve but maybe I should for when I need to replace the salt cell...? I try to think ahead to avoid "ah crud" issues.
My warranty is for 7 years (10,000-15,000 run time hours) or something close to that. Not voided if I install which was a selling point.
Oh I’m so jealous of your nice weather all year round, I’m I’m Connecticut hate this long depressing winters ???I don't have a heater core (unless there's one in the unit) and haven't read through the destructionsROFLMAO
completely yet. I am trying to finish those before EOD today.
Yes I was going to move to Austin but last minute stay caused of family :/I know a few people up there in Connecticut and I lived there for about 6 months (winter) years back. I was young when I was there and the weeks without sun definitely did me in. I moved back home.
