I've been on vacation for 4 days and I returned home to find my pool is green.
(I can see the bottom, but barely) I've put in two gallons of bleach, 1/2 lb baking soda and the pump is running. Thats all I had on hand. I have an above ground, 15,000 gal, sand filter. My readings after doing this are
TC 5
FC 4
alk 40
PH 6.2
Should I vacuum and backwash before adding borax and more baking soda? How much of each should I add? more bleach also? and let the filter run?
What others suggestions to bring the #'s where they should be?
This is the only test kit I have so far--I have ordered a better one it just hasn't arrived.
Thanks in advance.
TC 5
FC 4
alk 40
PH 6.2
Thanks in advance.
