Since some of you mentioned you like transformation pictures. I just added 230 fl oz of chlorine FC tested 1.5-2 ppm. The pool looks way better in my eyes anyway. Still little green and very cloudy. Let me know if I am delusional or something
Keep with theAnother progress picture. I can see algae is gone (most if not all) but now it is cloudy. How do I deal with it?
Keep Doing all the things
*Check & scrub every nook & cranny where algae may hide (light niches, steps, drain covers, ladder handrails, skimmer throats/weirs, abandoned lines, autofill, overflow drains, etc.)
*If water can go there, algae can thrive there.
*Run slam level water through all water features & lines for at least a couple hours a day during the SLAM Process.
*Brush & or vac daily (this breaks up biofilms that algae uses to protect itself from chlorine)
*Backwash/clean filter when pressure rises 25%over clean pressure.
We’ve seen worse be turned into a sparkling oasis so don’t worry, it will happen, it just won’t happen overnight![]()
Looks even better than yesterday! You’re getting there!Some progress pictures. It looks better everyday.
Both tests should be done in the dark to remove the sun/uv from the equation.Some questions that I will appreciate some help with.
1. I added chlorine to raise it to 12ppm at 11pm yesterday. Today at 830am I was at 2.5ppm. So I haven't passed this test, is there anything I should be aware of when taking these readings so I can pass this test?
2. CC this morning was 0.5, so I passed this parameter. I even noticed less odor from the pool this morning. Isn't passing the CC test means that no algae is present? Why is FC dropping overnight?
ThisCC is not a primary indicator of algae. It is tied to ammonia based contaminants.
Filter, filter, filter- clean them frequently.3. Pool is very cloudy with some white/grey residues on the step I can see. So I can assume it is all over the pool. What can I do to clear up the cloudiness so I can see the floors and start cleaning it?
Never fear! You got this!Thanks for all the help guys you all have been amazing throughout this process. This has been stressing me and I was on the edge of giving up and hiring someone.
Thanks for all you follow up during this process. I scrub and run the bot at least 3 times a day. When I open the autofill valve I only see the float, nothing to scrub really. The over spill uses the primary pump, but I have another water feature pump which I rarely use. I didn't run it during the SLAM before but will start running it for couple hours starting today.Looks even better than yesterday! You’re getting there!
You must also test after your last addition to confirm your fc level (about 30 minutes after)
That is still quite the fc loss, I see you have spillover/waterfall type water features, be sure you are running slam level fc water through all water features a couple of hours each day. Get at any nooks & crannies you can with the brush. Blindly brushing is fine. If you have an autofill check/scrub the pot & the overflow drain. All crannies are suspect!
This
Do you have a manual vac you can use as well?
Does your bot have ultra fine pleated cartridges? If so, use them & run it often.
Brush, brush, brush- brushing blindly is fine. This breaks up the biofilms algae uses to protect itself from chlorine allowing the chlorine to kill it. It also stirs things up so the filter can capture them.
P.s. - you’re logging your additions in poolmath but not your test results.
This makes it hard to see the patterns/progress & leaves us having to do a lot of math to figure those out.
Next test , log your results first then they will show in the overview cards as “current”
You still have active algae as shown by your large FC losses. Follow the process.Can I ask my TFP is against using a clarifier at this stage?
FantasticThanks for all you follow up during this process. I scrub and run the bot at least 3 times a day.
GoodWhen I open the autofill valve I only see the float, nothing to scrub really. The over spill uses the primary pump, but I have another water feature pump which I rarely use. I didn't run it during the SLAM before but will start running it for couple hours starting today.
Vacuuming bindly is fine - vacuuming to filter is fine too- it gets the stuff off the floor & into the filter then you can clean the filter.I have a manual vacuum, but I have never used it and I don't have a set up to vacuum to waste, I will have to vacuum to the filter. I have a valve at the pump discharge and vent at the top of the filter that can be used to waste most of it. But I can't see the floor so not sure what to Vacuum. Also the cloudiness is in the water itself not just the floor.
#1 clarifiers gunk up your filter mediaCan I ask why TFP is against using a clarifier at this stage?
Thanks for the clarifier clarification, makes sense.Fantastic
Goodif water can go there, algae can grow there.
#2 Because it can make the water look better temporarily (a bandaid if you will) causing you to think you have passed the clear water test even though all the algae isn’t eradicated.
This can lead people to end slam prematurely.
When there is no more live algae to be killed the dead algae will become less & less until it is eventually gone resulting in the crystal clear water (with no algae- dead or alive) . This is an important metric in the slam process.
Wait, What?I control the pump at 45 gpm most of the day and 55 gpm for 6.5 hours during SLAM.
You may want to open it up & look at them.Thanks for the clarifier clarification, makes sense.
I haven't cleaned the filter once since I started SLAM, the cartridges are 2 weeks old. Pressure is very stable. I control the pump at 45 gpm most of the day and 55 gpm for 6.5 hours during SLAM. I also track power consumption and RPM as a way to measure filter resistance. It has been stable and no increase has been happening in pressure, RPM or power consumption.
Do I still need to clean the filters, or I am good if pressure and GPM are stable?
I run it 6.5hrs at 55gpm and 17.5hrs at 45gpm. I test a lot. At the beginning I was adding chlorine 6-8 times a day. Now it is around 3-4 times a dayWait, What?
Shock Level AND Maintain. SLAM is a 24 hour process. It is not a 6.5 hour process. If you can, test every 2 hours, raise back to shock level per your CYA.
My old cartridges were very bad. They would increase the filter pressure in 2 weeks after cleaning them. They were the original pantair cartridges. The top and bottom were torn and some of the straps holding the media were torn as well. I throw them away as I didn't believe I will ever need them with their condition. Pool was built in 2021 and they are the original ones that came with the filterYou may want to open it up & look at them.
If you have your old filters you can swap them out & have almost no down time while you clean the others.
Unless the filters are worn/torn they should last several (5+) years before actually needing to be replaced if cared for properly.
Cartridge Filter Use and Care - Further Reading
www.google.com
