I can track gpm and consumption from my phone. But I can't track pressure.Instead of messing with GPM, power consumption, etc - run at a fixed RPM 24/7.
Clean your filters and note the clean pressure. When filter pressure rises 25% of clean pressure (use a high RPM to check this), clean the filters again. Rinse, repeat as necessary. During the SLAM Process, you may have to clean the filters several times. And clean them again once the SLAM is complete so you are starting normal poll ops with clean filters.
If cartridges are properly cleaned, they can last 7-8 years. 2 years is a pretty short life span.
Also I noticed when I run at fixed speed and the filter get clogged. Gpm drops as the pump can't compensate for the higher flow restriction and consumption goes down as the pump is pushing lower GPM at higher head as the speed is constant (verified in the pump curve). I have monitors installed in the panels and can set up an alarm on my phone to alert me to the higher pump consumption so I can clean the filter. Doing this will help me not lose GPM when the filter get clogged and save on power consumption when filters are clean.
What is the proper way to clean the cartridges. Just hosing them?
