Did you add stabilizer to increase the CYA to 30 or not?
At low CYA levels, the chlorine will burn off fast in the sun.
You need to follow the
SLAM Process to the letter.
No shortcuts.
If your CYA is less than 30, it needs to be increased to 30.
SLAM level for CYA 30 is 12 ppm FC.
Your pool didn't get algae and turn green in a day. It will take time to get it clear again.
We can't predict how much liquid chlorine it will take as each pool and algae situation is different.
Stay the course.
At the stairs, put the pool brush into the pool as deep as it goes.
Take your pics in that same location - with the brush in - seferal times daily. This will provide a visual indication of water changes.
