Heater Bypass
Mine is plumbed without a bypass as well (unless you consider the pressure vacuum port a bypass) but they did use the Versaflo connections. This really has to do with the plumber that is on the job. I would have loved to have a heater bypass but I didn't know enough to ask at the start of my build.
KIR59Ja3XEF93M8emym8EteBahSvjiOV_uOUiN8pRQ9uIoV5jcittrfKn2J8rVremIibXi4zviKsRgAkAWAfC_JQ-QXalkVyL4IWiJQMPu-x_4Mv2zTqJhI3tX2ScG3WkmnTGsm0-l5xNxhmxJ9iZpHMJizWVK8rrCKfE3BhqOmgf4imAzToXXYIznyuAhpxZ3grpfHDIPS9qvyGq-iyZf2GjnNyHBeD6mk9mlJLGK_K5-Cy-uUJekXkqZW73OF1ZJ3_u9pNixeprDBDwyn0RUmZD-wL_MuEvXnz1j75QuX1EnzG_EXbO7bWyuvf3ffvo5iHuOG2LID4oyi6Ov4Sd5Jpf_uOtjemA6M8CR2yHi4VoiZYi91eEGIITtzxmj8bB6kiAx29yVKAkIDMl-yQ8Noxlt2uRdl9R3iMKkHp1y8LqL3A_Bbg6f36jeF2XpS6rV1XbWibzTUSJAjaLjRtJ4w5l94riqwPdPnF1QdDvYkBLOHn1bUgI654f4GKQxJ5waYHYNhm5oUp13ZgcZtLl3SVRVtoHoC1c-Y1Br5pTXV7uyds_1CBf_BXQ4ANzwVkrOqknWC6XTNyryTwIxmv9cRbsaccV4ZIm-bn2jRneIasOjVrLt99ErPakrTKpQrpBU7wUYEyAOjB9CX4xINtXIIugebfDOFk=w1705-h959-no
Afternoon. So quick question. Going though a new pool build. Builder is using Jandy JXi. Any reason why they wouldnt have plumbed it without a bypass or using the addon of the Versaflo?
Thanks!
Chad
I built with Hauk and I did the VersaFlo Bypass. I believe I had to ask them to install it. I believe the bypass is extra money.
I absolutely love my Jandy heater, I heat my spa probably 2-3 times a week and barely notice a big bump in energy costs.
I mean this video pretty much sums up why if you are getting a Jandy JXI you should install the bypass:
https://www.jandy.com/en/videos/heaters/jxi-versaflo
Thanks!
Chad
I believe Jandy doesn't recommend using a plumbed bypass for the JXi. My pool guy warned against it, and Jandy documentation I found confirm it. Maybe due to SWG?, but both said that stale water will decrease the lifespan of the element. The Versaflo (or built in one) isn't a traditional plumbed bypass, it still allows a % of water to circulate through the elements.
