Manual heater bypass for winterizing
Patrick1101
1
Raleigh, NC
I have a Pentair UltraTemp heat pump that I winterize every year by manually turning the 3-way valves to bypass it so I can drain it, shut off the power, etc... but yet, still keep my filter pump running. I just ordered a new Jandy JXIQ gas heater with the built-in VersaFlo bypass that I plan to plumb inline after the Pentair heat pump.
My question....do I need to install a similar manual bypass with 3-way valves to also bypass the new Jandy JXIQ gas heater so I can winterize it, I.e. drain it, shut off the power/gas, etc.. or does the VersaFlo do this automatically without the power being turned on? In other words, I want to drain and winterize both heaters, but I still need my filter pump to run.
VersaFlo does not stop all flow through the heater but allows a small amount through. If there is a danger of freeze, you need to install a bypass that will allow the heater to be drained and not have water in it during that time, just like the UltraTemp.
