- Jul 21, 2013
- 65,131
- Plaster
- Pentair Intellichlor IC-60
I don't know why your firemans switch control did not work but I would rewire it for RS-485 control.
You need to reconnect the firemans switch wires in the heater and use the same cable yellow/green wires between the Comm connector on the heater board and the Comm connector in the IntelliCenter. Then change your gas heater configuration to Connected Heater as discussed above.
Always power everything down before making wiring changes.
