Hello everyone, wanting to say a big thanks to this forum as we have had beautiful clear water since our pool was build in June.
our pool specs are in my signature below. We just had a hayward pool heater installed today 100k BTUs. wanting to swim year round(in southwest Florida) plus I have a foot injury and swimming is allowed(and encouraged) for rehab so wanting to use the pool often(4-5x a week at least) day temps here normally around 75-80 degrees and nights normally around 60s but can get colder. Pool is currently around 64 degrees. Wanting to stay minimum of 85 degrees.
my questions are:
* should we leave the pool heater running nonstop if we plan to use it 4/5 times a week or is it possibly more efficient to turn it off/on as needed? Worried about expense if running constant(since I’m guessing the pump must run non stop to - currently pump runs 9 hours a day). What would you do in our case.. leave it all running constantly or try and conserve much as possible and turn off occasionally.
* if we do try to turn it off/on and not run constant how early should we turn it on before hoping to swim? We have a fairly small pool but not to sure about this one As to how long it takes to heat up at 85.
*if we let the heater run nonstop, is it ok to let it shut off when the pump shuts off(so would run 9 hours a day) or would this not work as 9 hours a day won’t keep the pool temp steady..? just really unsure the best approach considering we would like to use it more often...(if possible without a enormous electric bill).
any advice is appreciated!
my questions are:
