You mean your heater?
I see what you mean on Page 35 of the manual - https://cdn.globalimageserver.com/FetchDocument.aspx?ID=A6A43ED9-CCB9-4449-B4AF-AF6111D27828
If you intend to close the pool and winterize it then you need to have that fixed or you will need to open up the unions to blow out the coil.
Or you can plan to keep your pump running in any forecasted freezes.
I finally got around to adding another valve to make a true bypass; the installer missed that originally on the outlet (upper pipe on HP). Oddly, when I opened the drain plugs on the Heat Pump unions, It's clear a little water is making it past the valves?! When the pump is running and the water set to bypass the HP a short blast of water comes out of the plug(s) when opened. It doesn't seem right that water would be making it past the valves?! Thoughts? Thanks so much!
