Hi, all!
I hope everyone is doing well. I'm also looking for some advice on replacing my pool vacuum. When I bought my house seven years ago, I inherited a Haywood Pool Vac XL. To the best of my knowledge, it was purchased when the pool was put in, so it's about 14 years old. I've replaced the shoes every year, the turbine and other internals twice in the past seven years, but it's showing it's age and I'm going to replace it. I replaced the pool pump about four years ago and went from a single speed to a Pentair variable speed.
My question is, should I replace the pool vacuum with the same model, which has worked well over the years, or change to the Haywood Pool Vac V-Flex, which I've been told works better with variable speed pumps. My pool is oval-ish shaped, about 30 ft long and 10 - 13 ft wide. It starts off 3-1/2 ft deep and goes to almost 6 feet. I've estimated it at 13,000 gallons, if all this helps. Haywood has a $100 rebate and Leslie' pools has a sale, so I was thinking of getting it this weekend.
Thanks in advance for your advice! Be well and have a great weekend!
Mike B.
Mike B.
