I have a Hayward SP3400VSP pump for my inground pool. Yesterday the pump was running fine, today it wont run.
It has a SP3200DR control pad, there are no error messages on the LCD screen and everything is showing normal.
When you turn it on either with the timer setting, "Quick Clean" setting, or preprogrammed setting it shows the RPM setting, but the watts say 0.
I've disconnected the power to it to see if that rests it, nothing happened. I even took the control pad off, unplugged it, popped out the standby battery and nothing happened.
Could this be a short in the circuit board?
