Hayward SAS-ABG
lplatz
Active member
Jun 20, 2019
30
Royce City, Texas
Thermistor is a two wire resistive temperature device. If you read resistance with a volt-ohm meter, it is probably good. Open circuit or short circuit is bad. Usually they are 100 Ohm, 1K Ohm or 10K ohm. not sure on this particular one.
When I test the Thermistor, I don't need to pull it from the board do I?
lplatz
Active member
Jun 20, 2019
30
Royce City, Texas
Question on the plumbing for the new T-Cell-15. Confirming this Cell does not need a flow switch? Also, can this cell be installed horizontally?
C0d3Sp4c3
139
NorCal
The Hayward Turbo cell 3, 5 , 9, and 15 physical dimensions are the same and requires no plumbing mods to interchange.
Correct, the Aquatrol RJ model does not need a flow switch. And yes, you can install the T-cell horizontally but why would you on a RJ? Please take a gander at the Aquatrol User Manual
