Just let them confirm and explain why they blame the pump before the installation otherwise after the install they may find the real culprit and you end up with a repair bill that is unnecessary.
Not sure honestly… unfortunately I wasn’t home during that part of the install.Did the new pump lid O-ring get some lube?
Some techs slap the new pump on and leave. I would check that O-ring when you get a chance. Make sure it has a nice coating of pool silicone lube.Not sure honestly… unfortunately I wasn’t home during that part of the install.
Good idea! I may just go ahead and order some to be safe. Something like this? Super Lube 56204 O-Ring Silicone Lubricant, Clear https://www.amazon.com/dp/B07C3CZ9CL/ref=cm_sw_r_cp_api_glt_i_2DM53R02F8TRGFDCSWYASome techs slap the new pump on and leave. I would check that O-ring when you get a chance. Make sure it has a nice coating of pool silicone lube.![]()
I get bubbles during prime (which is 3450 RPM I believe) and also during normal operation (2000-2800 RPM). I inspected the pump skimmer basket O-ring and the check gauge O-ring, and both look ok. The interesting thing is that after the install of the new pump, there were no bubbles for a few days, then they just started coming out of no where. I really hope it's not a crack in underground plumbing...It's really hard to see the bubbles in the pic, but if you are running at a very low 1200 or less RPM, there's no issue w a some minor bubbling; but if bubbles appear in prime or higher RPM, 2200-2500 RPM, you have an issue.
Update: somehow this morning all the bubbles were gone! I didn't change anything, so I'm a bit confused. The only thing I can think of is that the temps dropped from about 70F yesterday afternoon to the 30'sF overnight. Could that drop in temperature make the bubbles go away (maybe by shrinking the O-rings a little)?
Update 2: Now, about 24 hours later, the bubbles are back again. No changes made on any of the equipment. I'm beginning to think it could be the changing temperature or possible a leak somewhere...
And what exactly is this “Bama Bug…” haIf anything, a shrinking of the O-ring w cold temps would cause for contraction, thus more potential air gaps, heating and expansion the opposite. I think you may have a "Bama Bug" somewhere in your lines... :-0
That's what the dawg's have been fighting for years and finally broke the code this final game, just like the Aggies did twice. ;-) You guys played a great game.And what exactly is this “Bama Bug…” ha
Haha! I’m glad it finally happened.That's what the dawg's have been fighting for years and finally broke the code this final game, just like the Aggies did twice. ;-) You guys played a great game.
ROFLLLLLLLLL You could have it, here you go:Haha! I’m glad it finally happened.
And here I am googling “Bama bug pool problem”![]()
