Not directly. Hayward wants you to use the Omnilogic if you need more than 4 actuators.
Or you can control an actuator using a high voltage AUX relay using this circuit. AUX relays use two wires - 24 VDC and ground. Valve actuators use three wires - two 24 VAC lines and ground. AC on one line will turn the valve one way and AC on the other line will turn the valve the other way.
You could use the AUX relay to control the 24 VAC so that it will turn the valve using the following circuit. But normal AUX relays won't work as they do not have any Normally Closed contacts. You need to change a relay to one that has NC and NO contacts.
