I was recently flooded by Hurricane Helene so I searched high and low to get a direct replacement for my Hayward MaxFlo VS 500 pump. Got it today, wired it up just like the one that was flooded - dip switches all set to 0, automation control set black to 2, yellow to 3 and gray to 4 and of course the power and grounds connected. In the original the grey conduit from the display dead ended into the 1/2/3/4 block and was left loose inside the cover by the equipment installer with apparently no issues. So we just wire nutted each of those four lines individually.
When I flip the breaker, there is live power to the unit on both the incoming wires and the wires inside the unit. The Hayward automation turns on and even says that the pump is turned on. However the display does not light up (I don’t recall if the original pump ever lit up as I usually only looked at the automation). There is also a red light emitting from the COM side of the enclosure - just a steady red light.
Any idea how to get my pump to actually pump?
