- Jul 10, 2021
- 11
- Vinyl
- Hayward Aqua Rite (T-15)
I have two Hayward light fixtures: SP0573LN50. The previous owner/maintainer used a screw with very broad threads for plastic where they should have used a machine screw and based on forum advice, I ended up drilling it with an air drill. I was quite proud of myself. I changed the light bulb in both fixtures. A few weeks later one bulb was flashing and a bit later the gfci tripped. I pulled the lights. One had water in it. I let it dry, changed the seal, and put it back. The gfci is tripping again so I assume it is now full of water again. I have new gaskets and I bought new retainer clamps for when I pull the lights out again.
I have two questions:
1. How tight should I tighten the retainer clamp? SPX0580B.
2. Is there a certain orientation for the retainer clamp?
