- May 17, 2019
- 403
- Plaster
- Pentair Intellichlor IC-60
it was professionally closed so I really really hope not!Curious what you find..I wonder if it froze.
Ok good tip. Assume I need to get the case of the heater off to stand a chance at hearing anythingListen carefully to the heat exchanger when you turn the pump off to see if you can hear air getting sucked in.
Just listen at the outlet vent.Assume I need to get the case of the heater off to stand a chance at hearing anything
Listened there but didn’t hear anything like air sucking when the pump went off.Yes.
Below it. A few feet maybe? Why?What is the height of the heater relative to the pool surface?
If the heater was above the pool, air would get sucked in at the leak point.Below it. A few feet maybe? Why?
If the heater is below the pool, air will not get sucked in.
I suspect that the heat exchanger is leaking, which usually means the heater is not worth fixing.
If the heater is more than a couple of feet below the pool surface, the heater pressure switch can be activated by the water pressure from the height of the water with no flow, which would ruin the heat exchanger.
Once the combustion chamber insulation gets soaked, the heater is not going to work right.
Don't even try to run the heater until the leak is identified.
And to be clear, the heater never ran with the pump off so i believe the pressure switch was adequately set so as not to allow the heater to turn on with the pump off.If the heater was above the pool, air would get sucked in at the leak point.
You don't know that for sure.the heater never ran with the pump off
Gotcha. Posted some pictures. The fins don’t look annealed or anything. Just blue.The manual will specify the allowable height differential. The pressure switch can be adjusted somewhat. If the height differential is too much, you have to install a flow switch.
The gorp on the igniter also looks like there's a leak somewhere.I suspect that the heat exchanger is leaking, which usually means the heater is not worth fixing.
