Hayward H250 Pool Heater
After looking at an enlargement of the ICB, there it was in the upper corner. Pulled it out, and it is blown. So I will be down to the pool supply tomorrow for another one (and a spare!). One thing I wasn't told when the unit was installed 5 years ago, was there was a packet inside with the 3 slow-blow fuses and the other one! It had moisture inside, so none of these now work, and I will make my own spare package that is kept in the main Hayward supply cabinet, which is water-tight. Maybe this is useful for anyone else that has had a pool heater installed. Thank you James W. for your help.
You might be able to find the fuses at a hardware store or automotive store.
The pool place might have them but probably not. Even if they have them, they will probably be more expensive.
A blown F1 fuse might be bad wiring, a bad gas valve or a bad ICB.
