Hayward Aqua Plus Blows 20 amp fuse
Joey Finnegan
5
arkansas
I have a Hayward Aqua Plus. The screen read no cell power. I removed the board and checked the common relay “bad solder” connection and it looked fine. I then found the 20 amp fuse blown. I replaced it and powered up. As soon as the salt cell kicked on “pop”, it blew the fuse again. Where do I go from here?
I have a Hayward Goldline Aqua Plus that says “no cell powe 1”. I pulled the board and verified the relay solder joint was good. Found the 20 amp was blown. I replaced it, powered everything back up and as soon as the salt cell started the fuse blew again. The pump runs fine but there is a delay before the salt cell starts up. I can watch the timer count down and as soon as the timer hits zero and the cell tries to come on “pop”, blown fuse. Any directions? Is there a schematic to look at somewhere. Could it be a short in the salt cell itself or is it more likely the board?
Check the bridge rectifiers for shorts.
Checking bridge rectifiers is being discussed in…
Reactions: Joey Finnegan
So if I understand this schematic the salt cell is probably not shorted (a lot of YouTube said it could be the salt cell). I assume the rectifiers are changing ac to dc, correct? So I’m an auto tech and understand DC automotive circuits but I’m rusty on ac such as transformers. What is the fuse protecting? The board itself. Does the transformer just change voltage to a different output level?
You got to ask the YouTubers about why they say what they do.
Yup.
The transformer output.
Transformer takes in 120V or 240V and outputs about 24V.
If the cell had metal bridging the plates, it could short out, but that would be very unusual.
The center plate and end plates get voltage, so you would need a metal bridge from center to either end.
Maybe a spring from a heater bypass.
Pop off the cell cap and check the wires.
