Hayward Aqua Plus Blows 20 amp fuse
Joey Finnegan
5
arkansas
I have a Hayward Aqua Plus. The screen read no cell power. I removed the board and checked the common relay “bad solder” connection and it looked fine. I then found the 20 amp fuse blown. I replaced it and powered up. As soon as the salt cell kicked on “pop”, it blew the fuse again. Where do I go from here?
I have a Hayward Goldline Aqua Plus that says “no cell powe 1”. I pulled the board and verified the relay solder joint was good. Found the 20 amp was blown. I replaced it, powered everything back up and as soon as the salt cell started the fuse blew again. The pump runs fine but there is a delay before the salt cell starts up. I can watch the timer count down and as soon as the timer hits zero and the cell tries to come on “pop”, blown fuse. Any directions? Is there a schematic to look at somewhere. Could it be a short in the salt cell itself or is it more likely the board?
Check the bridge rectifiers for shorts.
Checking bridge rectifiers is being discussed in…
Reactions: Joey Finnegan
So if I understand this schematic the salt cell is probably not shorted (a lot of YouTube said it could be the salt cell). I assume the rectifiers are changing ac to dc, correct? So I’m an auto tech and understand DC automotive circuits but I’m rusty on ac such as transformers. What is the fuse protecting? The board itself. Does the transformer just change voltage to a different output level?
You got to ask the YouTubers about why they say what they do.
Yup.
The transformer output.
Transformer takes in 120V or 240V and outputs about 24V.
If the cell had metal bridging the plates, it could short out, but that would be very unusual.
The center plate and end plates get voltage, so you would need a metal bridge from center to either end.
Maybe a spring from a heater bypass.
Pop off the cell cap and check the wires.
The people who answer questions are volunteers.
If you find the site to be a good resource, please consider making a donation to help support the site.
Thanks.
From the schematic, if you want to follow up on the possibility of the rectifiers being shorted:
  • Unplug the cell
  • Unplug the 2 yellow transformer wires from lugs on the board.
  • Replace the fuse (again).
  • Measure resistance (ohms) between the two lugs on the board that the yellow wires were plugged into.
  • Swap the meter leads and measure again.
Very high or "infinite" resistance in both readings means the rectifiers aren't sorted. If you get something low - maybe 1.2 ohms or less would blow the fuse - either way, then the rectifiers are bad, shorted. For an electronic tech of any skill, replacing them is an easy job. The parts are probably $10 at most and labor less than an hour.
You can next short the cell wires with a jumper (power still off) and measure again. This time you should get continuity (low readings) in both directions if the rectifiers are not failed open.
If you do get very high resistance at the lug s on the first test, then there's a short almost certainly toward the cell. Either the wiring or the cell itself. You can follow up on that with the meter in resistance/continuity mode, just as you would for car wiring. The cell when passing water should also have a resistance well above the 1.2 ohms that would blow the fuse.
