So I built a pool and finally got the liner and and filled two days ago. Lost 2.5-3” of water the first 36 hrs. Did a diy dye test and found two of three lights have leaks. Liner guy said the conduit is the issue but I found two of the plastic rings that squish the rubber gasket in place in the box still . Can I pull the lights and pop the rings on or will I flood my conduit and ruin things??
