- Jul 21, 2013
- 65,185
- Plaster
- Pentair Intellichlor IC-60
Thanks this is what I was looking for. How did you figure out the range? Is it based on the spec page for the VSSHP270DV2A?
Those are the minimum and maximum speeds your pump is run.
The more pertinent question is what speeds does your equipment need? This is where you need to do some experimentation and observation as each pools setup is unique...
What is the minimum speed that your SWG flow switch turns on? This RPM + 200 rpm in general is the minimum speed to run your pump while circulating the water. You always want to be generating chlorine while circulating water.
What speed do you get effective skimming of your pool surface? You will probably observe at the minimum speed for your SWG you don't get good skimming action pulling debris on the surface of the water into the skimmer. You need to increase your RPM to find a good skimmer setting and you can call that your pool cleaning speed.
What speed does your heater need? A gas heater needs at least 40GPM of flow. I don't think you have any flow display on your equipment. Too low a flow and the heater will not operate. A temperature difference between the input water and the out of the heater of about 13F will be about 50 GPM.
So your minimum pump speed is usually your SWG flow switch speed and the maximum speed to run your pump maybe your heater speed or your skimmer cleaning speed. There is no reason to run your pump faster then what any of your equipment needs.
On my pool my SWG speed is 1700RPM, skimmer speed is 2400 rpm and heater speed is 2600 RPM.
